Teamholmes18's avatar
Teamholmes18
Wall to hub cable
Hi there
I’ve  been trying to get through to someone at VM all day but to no avail. I have had a 360 TV box today and could do with a longer cable which goes between the wall box and the new splitter I’ve had. I’ve read Virgin do a 3 metre lead but I can’t get through to anyone to ask for one. Are these leads standard coax leads that I can pick up from a diy store or are they specially designed and wired?
Many thanks!!
Duncan
  • Daniel_Et's avatar
    Daniel_Et
    Hi Teamholmes18 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problems you've been having getting through to the team 😔
    I can see you've spoken to an agent since you posted. Has this now been sorted out?
    Regards,
    Daniel
    • Teamholmes18's avatar
      Teamholmes18
      Hi there
      yes.. I’m just awaiting the arrival of the cable, so hopefully should all be sorted soon. Thankyou!
