on 26-12-2023 12:52
Hi all
Upgraded to 360 few months ago and have noticed the sound varies greatly between channels. For example BBC channels seem very quiet and we have to turn the volume up quite a lot but then when you switch to ITV the sound blares out at the volume we have it for BBC channels. This is just one example. Movie channels also seem quite quiet and muffled at times.
It's not our TV as we notice this across all three TVs we view on (an LG TV and two different model samsungs).
Is this a common issue and is there a fix to get the sound more consistent across all channels?
on 27-12-2023 18:19
Have you tried the different audio settings, if you have it set to follow content try the 2 PCM settings. If you are using a soundbar with Dolby Atmos you will need the 360 set to follow content.
on 27-12-2023 19:19
on 28-12-2023 08:52
My 360 box is attached to my Pioneer Home Cinema Receiver, and yes I do have the same problem with varying sound levels on different channels. I guess it is just one of those things, I just simply use the receiver remote to turn up or down the sound depending on which channel I am watching. Just have to bear with that I'm afraid. By the way, I don't think there is a fix to correct this either as you asked.
