Ataxtos's avatar
Ataxtos
10 months ago
Hub5 and Access point
I have upgraded to Virgin Hub5 1GB from 500MB. I have 4 TP Link POE WIFI access points around the building using  ethernet cables from the router and worked perfectly with the 500gb Virgin router.. They power up now but no WIFI from any access points. Tried everything, reset router, reset Access Points and still nothing.
Any help would be brilliant
    POE Wi-Fi APs would need a POE switch to supply the power to the 4 APs.
    Since the Hub 5 was installed, has the POE switch been Rebooted ?
    Hub 5 has issues with its 2.5Gb/s port, try using one of the 1Gb/s ports
    to see if that helps to restore the connection to the POE switch & the 4 APs.
    How are the 4 Wi-Fi APs being allocated an IP ?
    • Ataxtos's avatar
      Ataxtos
      Hi I the APS are TP LINK EAP225'S they power up fine but just no wifi. I have 2 connected to the 2.5GB port and the other 2 on 1Gb port. They are all wired up individually back to the router.
      Hope this helps
  • What model of access points?
    If they are 10/100 (100Mbps) the HUB 5 may have difficulty with them or the switch, I assume, that's providing power to them.
      • legacy1's avatar
        Not sure what your getting at the POE AP get powered by something else not by the router
    You will need to reconfigure the AP’s.  Try using the Omada app on your phone. It should find the AP’s and allow you to configure them. I have 3 EAP610’s and they work perfectly.
      That is like offering the fellow a wine box when he is used to fine Burgundy !
      pedlar1 wrote:
      get VM to supply VM wi-fi pods, entitled to 3 on 1gbs
      I wouldn't touch them personally .....
      • pedlar1's avatar
        pedlar1
        Up to speed
        Why? is there a problem? as with getting Hub 5 ??
