Ataxtos
2 years agoJoining in
Hub5 and Access point
I have upgraded to Virgin Hub5 1GB from 500MB. I have 4 TP Link POE WIFI access points around the building using ethernet cables from the router and worked perfectly with the 500gb Virgin router.. They power up now but no WIFI from any access points. Tried everything, reset router, reset Access Points and still nothing.
Any help would be brilliant
