on 16-12-2023 17:42
Had a replacement hub connected now I can`t access my cctv on other devices. Cctv monitor is saying "gateway unreachable". The helpline has advised me to manually input into the cctv system the hub IP address and the hub gateway details. I`ve logged in to the hub`s menu and can`t see the info I need. Can anyone help please. Thanks
on 16-12-2023 19:00
on 16-12-2023 19:48
How do I find that?
16-12-2023 19:55 - edited 16-12-2023 19:55
What IP address does the app use to access the CCTV?
Is it a 192.168.x.x address or another format?
on 16-12-2023 21:34
on 17-12-2023 19:43
IP address on the cctv system says 192.168.x.xx. Everything was working ok on the app until the hub was changed
on 17-12-2023 19:58
Has the cctv system been rebooted since the HUB replacement?
The new HUB may have provided a new IP address, however, the cctv hasn't refreshed for some reason.
on 17-12-2023 20:03
When the Hub is replaced, it is critical to power cycle ALL network devices ( CCTVs / DVRs / MOBILES / TVs / etc... )
Has this been done ?
on 19-12-2023 00:24
If you can't get it working go get a new router with 1Gb ports and put hub in modem mode
