- newapolloVery Insightful Person
Hi Nevisthedog
Have you tried the three different audio settings on the Stream box?
Settings > Audio & Video > Audio Output.
There is Follow Content (recommended) The box should automatically select the best audio output.
PCM 5.1 (HDMI Only) Normally used for sync issues
and PCM2.0 this one usually solves common sound problems.
- NevisthedogJoining in
Thanks for your reply, doesn’t seem to make any difference. The other thing I noticed is, the picture quality of virgin stream Sky Sports hd isn’t as good as the BT box Sky sports hd, in fact I had to upgrade to uhd !
- Daniel_EtForum Team (Retired)
Hi Nevisthedog, thank you for your posts.
We're sorry to hear about the problems you're experiencing 😔
How have things been since you posted? Advice on how to fix TV issues, including those related to picture and sound, can be found here.
Thank you for your support newapollo 👍
Regards,
Daniel
I tried all the settings and actually one did sound louder and clearer, so yes thanks my problem is solved.
- Gareth_L
Hello Nevisthedog.
Thank you for your reply. Glad to hear you have been able to fix the muffled sounds on your stream box.
If you need any more help or have any questions, you know where we are.
Gareth_L
Related Content
- 2 years ago
- 3 years ago
- 6 months ago
- 2 years ago
