on 01-11-2023 20:55
I am a live streamer and had the 350 package which i found my upload speed being erratic and my livestream kept lagging. called virgin media and they advised me to upgrade to the 1gb connection which i did and after a few days started to see the same problem with my upload speed. after many phone calls to virgin media they have now said that my upload speed is being throttled! so what a waste of money since i upgraded to the top tier internet. con
on 01-11-2023 21:02
on 01-11-2023 21:04
I have just been told that im being throttled by virgin media themselves
on 01-11-2023 21:14
I have just been told by a virgin media call centre that my upload has been throttled.
01-11-2023 21:24 - edited 01-11-2023 21:25
@pringlesdomain wrote:I have just been told that im being throttled by virgin media themselves
They are talking out of the wrong end to get you off the phone.
01-11-2023 22:45 - edited 01-11-2023 22:51
So what is your upload speed showing by speed test sites?
VM do have the ability to throttle which might be down to the limited upstream that you and others are causing problems for others for high pings
limit your bit rate streaming
on 01-11-2023 23:42
my upload is fluctuating it should be 104 upload but im getting low upload speeds where it will end my stream
on 01-11-2023 23:43
im also streaming at 6000 bitrate which is only 1920x 1080 not full 4k
on 02-11-2023 06:14
Did you actually do the realspeed test as asked? I also wouldnt expect congestion to end your stream, just to cause buffering instead.
As said VM dont throttle.
on 02-11-2023 11:58
VM won't deliberate apply throttling, but if the user is exceeding the available uplink capacity the result is the same.
