vekete's avatar
vekete
12 months ago
confused as hell what speed i am getting? recently upgraded to 1gbp
so i have a cat 5e cable and the vm is in modem mode
it connects to my ps5 or apple tv - i change whenever im using one as i only have one cable
on apple tv when i do a test if its on server tnp i get 500 mb on razorblue i get 950 mbps ( i dont think i can ever get 1130 unless i get cat 6)
the same ethernet connected to my ps5 gets either 100mb or like 600-800mb i dont know how as uits the same wire as the apple tv
im not really sure what to do? my router is the asus axe16000
if i have to manually choose a server then how do i know what server my ps5 is on when playing
i think its maybe the cat 5e cable?
i did try direct from vm router but then i get bad signal around the house so i put it in modem mode
  • Tudor's avatar
    As speed is sometimes 100 other times much higher I would replace the cable. Don’t bother getting anything higher than a Cat6. If you want speeds higher than about 950, then your router must have WAN and LAN ports of 2.5G.
    .... and the device ( i.e. PS5 or Apple TV etc or computer ) must also have a 2.5Gb/s port !
  • Hey vekete, thank you for reaching out and I am sorry to hear you are having some connection issues with your PS5.
    Did any of the advice here help at all?
