danvm01's avatar
danvm01
12 months ago
VM Hub4 Fails diagnostic tests
I typically run in modem mode, however for the last week - it has been providing intermittent internet connectivity and dropping packets. Ping spikes up to ~3000ms after several hours requiring the Hub4 to be switched on/off. When it has been powered off/on - it returns back to normal service for between 3-18 hours then starts to misbehave once again.
I am now running the Hub4 in factory default mode and get an error when running (after factory reset) the network diagnostic tools that there is an error on "checking broadband service" red triangle symbol.
VM Agents have confirmed there is no external network network issues logged for the area.
Has my Hub4 developed a fault and needs to be replaced?
  • jbrennand's avatar
    Lets see the connection/Hub data - can you do this..
    _________________________________________
    Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
  • Hi danvm01
    Thanks for posting and welcome back to the community. Apologies for any broadband issues.
    I can see following a system check, you've spoke to the team since the post and booked an engineer visit.
    Kindly let us know how it goes.
    • danvm01's avatar
      danvm01
      John - Line checked out fine, engineer replaced Hub 4 to Hub 5.
      It looks like VM has not resolved the “YOUR ISP'S DHCP DOES NOT FUNCTION PROPERLY.” error requiring a MAC code to be put into my router so it can resolve and get an IP Address. Just as well, I know how to do this.
      Hopefully, we'll know over the next few days if the issue has actually been resolved as restarts of the prior Hub 4 gave service (slow service) after a period of time.
      • Zach_R's avatar
        Zach_R
        Hi danvm01,
        Thank you for getting back to us with an update. It's a shame they weren't able to resolve everything during the visit, but I'm glad to hear that you've since been able to tend to that final problem.
        Please do let us know if there's anything more that we can help you with.
