01-03-2024 18:16 - edited 01-03-2024 18:52
My two home servers run three staggered speedtests each every night - around 3am / 4am / 5am. They run so they don't happen at the same time, obviously.
Looking over recent results, I can see that my usual 100mbps upload speed has broadly halved since 10th feb. Not just a one-off, but halved across the board, every day, every speedtest, on separate machines. Both ethernet-wired so no wifi flucuations involved.
Server 1 graph - https://imgur.com/OZgW3JE
Server 2 graph - https://imgur.com/6yxGrQv
What happened on 10th Feb to cause this? Nothing in my network has changed in this period.
02-03-2024 14:01 - edited 02-03-2024 14:03
not quite. as i mentioned, one of the machine is wired directly into the orbi and the other is wired via a switch, so a switch isn't a common factor here. Both machines were happily reaching 100mpbs up as you can see from my original data, one direct and one indirect. The orbi is connected to the hub 5 via the 2.5g port.
However, the fact that wifi will reach 100 up is baffling and it would suggest somehow all the ethernet ports on the orbi degraded to half speed at exactlyn the same time. but that seems unlikley?
Something changed on or around 10th Feb. That thread referring to a firmware update around that date, and mentioning issues with the 2.5g port seems a bit too...coincidental? Especially when considering not a single thing in my network infrastructure has changed and it's all been working perfectly for as long as i can recall.
on 02-03-2024 14:37
lol so, I'm in no way a conspiracy theorist right.. but every single day since mid-feb my upload speed has halved. Then yesterday evening I post this thread, the speedtests ran overnight as usual, and suddenly these results for each server:
100mbps upload again, out of nowhere, with precisely zero change in my network environment.
on 02-03-2024 14:42
Connect by wire to the hub without a router and in modem mode and test speed
on 02-03-2024 14:46
@legacy1 wrote:Connect by wire to the hub without a router and in modem mode and test speed
What exactly is that going to achieve when speeds have returned to normal?
on 02-03-2024 17:40
Looks to me like VM were doing (unannounced) changes to their network. They often do that in the wee small hours but it usually only runs for a few days ... but they may have extended it in your area?
Next time check on the Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level - and see if anything is being reported on there
on 03-03-2024 08:19
Hello,
A gentle reminder to please keep replies polite, respectful and relevant, some posts have been removed
Lisa
on 03-03-2024 19:10
lmao who got upset over my upload speed?
on 03-03-2024 19:12
@chrisbm wrote:lmao who got upset over my upload speed?
Not upset, just pointing out posts that aren't helpful.
