RWR's avatar
RWR
So slow and unreliable! And very expensive!
Does anyone know how to contact VM directly, to cancel? I know they are holding me to ransom, and it will cost a fortune to break the contract, but I'm not paying £50/month for less than 10mbps, and frequent dropouts. It's just not fit for purpose, especially when working from home.
  • Tudor's avatar
    Have you reported the fault, what did VM say.
  • Thanks for reaching out to us on the Community Forums RWR, and a very warm welcome to you!
    Sorry to hear of the drop outs on the services.
    Can you please expand on this fault for us? - Does this perhaps effect both Wi-Fi and Wired connection?
    On Wi-Fi connections, does this happen in both the same room as the router or just when you're further away from the router in a different room?
    David_Bn
  • RWR's avatar
    RWR
    Thanks for your response.
    I have no wired connections, only WiFi. It happens on the same devices, not moving them. The speed might be 40mbps (not great but the best I usually get), then drop to below 10mbps (terrible) for days. Resetting the router helps, in the short-term, getting maybe 50mbps, for a while, before it slows again. This however, is inconvenient.
    Given the high cost of VM, I am surprised by this.
    • Ashleigh_C's avatar
      Ashleigh_C
      Hi there RWR
      Thank you so much for popping back to us and I am so sorry again to hear that this has been happening.
      Can I ask if you have run checks on your home set up via the Connect App at all? If so, what did this say?
