- carl_pearceSuperstar
KelseaJ wrote:My wifi speeds currently:
What I'm supposed to get:
What does this site show?
https://samknows.com/realspeed/
VM guarantee a minimum of 30Mbps over WiFi:
Full speed is across multiple devices at the same time.
- KelseaJJoining in
This is the speeds im getting on my computer
- legacy1Alessandro Volta
You have a cable from outside to inside did you really think wifi would give you the speed that a cable to the hub would do?
also get a better cable
https://www.amazon.co.uk/dp/B004WCPKPM/ref=twister_B005A7HSGW
I have no doubt your unhappy and you want VM to fix it or make it better with theirs pods that causes more trouble or you can get a better wifi router with 1Gb ports or better and put hub in modem mode
- KelseaJJoining in
im not using an ethernet cable for this device, this is just wifi, but i have used cat 8 and cat 6 cables for ethernet and it doesn't change anything. VM also guarantee a minimum of 30Mbps over WiFi but im getting 7Mbps
What device is it?
Given how they test hubs wifi you likely have a bad hub not that VM will think so.
run a ping check by CMD on a wired connection
ping -n 200 194.168.4.100
Related Content
- 1 year ago
- 2 years ago
- 7 months ago
- 1 year ago
