KelseaJ's avatar
KelseaJ
My wifi speeds are not what i paid for
My wifi speeds currently:
What I'm supposed to get:
    • KelseaJ's avatar
      KelseaJ
      This is the speeds im getting on my computer
  • legacy1's avatar
    You have a cable from outside to inside did you really think wifi would give you the speed that a cable to the hub would do?
    also get a better cable
    https://www.amazon.co.uk/dp/B004WCPKPM/ref=twister_B005A7HSGW
    I have no doubt your unhappy and you want VM to fix it or make it better with theirs pods that causes more trouble or you can get a better wifi router with 1Gb ports or better and put hub in modem mode
    • KelseaJ's avatar
      KelseaJ
      im not using an ethernet cable for this device, this is just wifi, but i have used cat 8 and cat 6 cables for ethernet and it doesn't change anything. VM also guarantee a minimum of 30Mbps over WiFi but im getting 7Mbps
  • legacy1's avatar
    Given how they test hubs wifi you likely have a bad hub not that VM will think so.
    run a ping check by CMD on a wired connection
    ping -n 200 194.168.4.100
