- Cardiffman282Wise owl
Unplug the hub for ten minutes and then power it back up. If still an issue ring it in as a fault again (and ask them to stop gaslighting you).
- isykk12Joining in
We have had this problem for about a week now and the lights been red we asked for a replacement but said we don’t need one and the option which we requested for a replacement was not there?
- AdduxiVery Insightful Person
If it is a Hub 3 AND if the red LED persists after a pinhole reset, the Hub should really be swapped out. This red LED is the overheat warning and should be working correctly.
If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
- isykk12Joining in
Yes I read I did the pinhole a week ago it’s still got the red light on
- David_Bn
Thanks for reaching out to us isykk12, and a very warm welcome to you!
Sorry to hear of the red light on the hub and the heat this is emanating from it.
Do please check out the envelope in top right hand corner for a private message from me, and we'll aim to have this replaced as soon as possible for you
David_Bn
Related Content
- 6 months ago
- 8 months ago
- 8 months ago
