- jpeg1Alessandro Volta
Assuming this is an ethernet connection, the usual reason for this speed is that the remote device is only connecting at 100Mbps instead of 1000Mbps.
Try a different cable, a different socket on the Hub, and check the ethernet settings in the device.
- Client62Alessandro Volta
You should see around 132 / 20 Mb/s on M125.
Seeing 90 Mbps over an Ethernet connection suggests your computer equipment has a link speed of 100Mb/s,
to go any faster you PC / laptop needs to connect to the VM Hub at 1Gb/s.
The Connected devices menu of the VM Hub is a good place check network link speeds. - Daniel_EtForum Team (Retired)
Hi max1000000, thank you for your query.
If you could try following the excellent advice provided by jpeg1, Adduxi and Client62, that'd be much appreciated.
If you're continuing to experience slow internet speeds thereafter, please let us know.
General advice on how to fix this type of issue can be found here.
Regards,
Daniel- max1000000On our wavelength
None of that works. I'm a seasoned user and elec eng. Had a replacement routers over the years, you name it. Rebooted, no change etc. Needs someone to come in and look at it.
Hi max1000000, thank you for your response.
In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
Related Content
- 2 years agoAnonymous
- 2 years ago
- 1 year ago
- 1 year ago
