Hi max1000000, thank you for your query.
If you could try following the excellent advice provided by jpeg1, Adduxi and Client62, that'd be much appreciated.
If you're continuing to experience slow internet speeds thereafter, please let us know.
General advice on how to fix this type of issue can be found here.
Regards,
Daniel
None of that works. I'm a seasoned user and elec eng. Had a replacement routers over the years, you name it. Rebooted, no change etc. Needs someone to come in and look at it.
- Daniel_Et2 months agoForum Team
Hi max1000000, thank you for your response.
In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel - Client622 months agoAlessandro Volta
So seasoned, you could not be troubled to expand on what is working correctly and what is not working as expected.
Related Content
- 2 months ago
- 2 years ago
- 11 months ago
- 4 months ago
