RitaC90's avatar
RitaC90
Intermittent WiFi after essential work
Hello!
after 6 years with Virgin I am considering moving to another provided.
At the beginning of the month I received this message from virgin announcing essential work at the beginning of Feb, after that I am having a lot of issues with my connection.
some days the speed in my office is 5 mb, and all the time I call I can’t see a solution.
they booked the first engineer to come last week just to find out the cancelled the appointment without notifying me.
now I have another appointment tomorrow and I have 0 hopes, what I know is that today I had to use my data connection to work.
We have some net gear boosters but nothing helps.
The only place with a good connection is the room where my hub 3 is.
router reset already completed.
I am so tired of calling them or spending hours on WhatsApp to try to sort this issue. Any advice for me?
also, don’t think this is normal customer care
thank
    Placement of Wi-Fi Repeaters is critical, they need to be in a position where there is a decent signal from the VM Hub.
    Check your mobile phone does work well at the chosen location before installing the Wi-Fi booster.
  • Daniel_Et's avatar
    Daniel_Et
    Hi RitaC90 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problems you've been having and that you're thinking of leaving us 😔
    How did the appointment go on Tuesday and how have things been since then?
    Thank you for your support Client62 👍
    Regards,
    Daniel
