  • Tudor's avatar
    Looks bad, please post some stats:
    How to get stats from a VM hub (no need to logon to the hub)
    Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
    • Click on the “> Check router status” button
    • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
    • Click on the “Upstream” tab, copy the text and paste into your reply
    • Click on the “Networking” tab, copy the text and paste into your reply.
      • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
    • richardmc85's avatar
      richardmc85
      3.0 Downstream channels
      11390000004.80000338.983261QAM2561
      21470000004.50000038.983261QAM2562
      31550000004.19999738.983261QAM2563
      41630000004.30000340.366287QAM2564
      51710000004.40000240.366287QAM2565
      61790000004.19999738.983261QAM2566
      71870000004.40000238.983261QAM2567
      81950000004.59999838.983261QAM2568
      92030000004.80000340.366287QAM2569
      102110000004.90000240.366287QAM25610
      112190000004.90000240.946209QAM25611
      122270000004.59999840.366287QAM25612
      132350000004.69999738.983261QAM25613
      142430000004.69999740.366287QAM25614
      152510000004.59999838.983261QAM25615
      162590000004.50000040.366287QAM25616
      172670000004.40000238.983261QAM25617
      182750000004.80000340.366287QAM25618
      192830000004.90000240.366287QAM25619
      202910000004.59999840.366287QAM25620
      212990000004.00000040.366287QAM25621
      223070000003.70000140.366287QAM25622
      233150000003.50000040.366287QAM25623
      243230000003.59999840.366287QAM25624
      253310000003.79999940.366287QAM25625
      263390000003.59999840.366287QAM25626
      273470000003.40000240.366287QAM25627
      283550000003.50000040.366287QAM25628
      293630000003.59999838.983261QAM25629
      303710000003.20000140.366287QAM25630
      313790000003.29999940.366287QAM25631
      323870000003.09999840.366287QAM25632
      1Locked38.98326100
      2Locked38.98326100
      3Locked38.98326100
      4Locked40.36628700
      5Locked40.36628700
      6Locked38.98326100
      7Locked38.98326100
      8Locked38.98326100
      9Locked40.36628700
      10Locked40.36628700
      11Locked40.94620900
      12Locked40.36628700
      13Locked38.98326100
      14Locked40.36628700
      15Locked38.98326100
      16Locked40.36628700
      17Locked38.98326100
      18Locked40.36628700
      19Locked40.36628700
      20Locked40.36628700
      21Locked40.36628700
      22Locked40.36628700
      23Locked40.36628700
      24Locked40.36628700
      25Locked40.36628700
      26Locked40.36628700
      27Locked40.36628700
      28Locked40.36628700
      29Locked38.98326100
      30Locked40.36628700
      31Locked40.36628700
      32Locked40.36628700
      3.1 Downstream channels
      159964K1840QAM4096424
      159Locked423.615230497843387
        richardmc85
        3.0 Upstream channels
        14960000046.5205995120 KSym/sec64QAM9
        22360000045.5205995120 KSym/sec64QAM13
        33010000046.0205995120 KSym/sec64QAM12
        43660000046.0205995120 KSym/sec64QAM11
        54310000046.5205995120 KSym/sec64QAM10
        1US_TYPE_ATDMA0000
        2US_TYPE_ATDMA0000
        3US_TYPE_ATDMA0000
        4US_TYPE_ATDMA0000
        5US_TYPE_ATDMA0000
        3.1 Upstream channels
        1410.048.52KQAM128
        14OFDMA20053.900
    Yes, something is badly amiss.  The power levels posted earlier are in spec but there are some strange looking log entries? To my untrained eye it looks like noise ingress, could be a bad connection, cable wear or something in the street cab?  It will take a VM tech to check this out for you.
    If you wait here a day or two a VM Mod should pick this up and discuss.
    • Paul_DN's avatar
      Paul_DN
      Hi richardmc85
      Thank you for reaching out to us in our community and welcome back, sorry hear your connection is dropping, we were able to locate you on our system with the details we have for you, we have checked everything our end and does look OK, however due to your stats we will invite you into a private chat as we would like to arrange a technician just to check the Omni Box, street cabinet and make sure your cable is OK, please look out for the white envelope.
      Paul.
  • Engineer been and fixed this issue. The connection between the external box and internal box on the house, that very short bit of cabling through the wall, was generating all of the noise and problems. All replaced and working fine again.
