tomsvirg's avatar
tomsvirg
Consistent drop in broadband speed
My internet speed consistently drops everyday, up to 20-30 times a day. WiFi always stays connected but nothing loads. I end up tethering from my mobile or just use 5G. Big problem when working from home.
Essentially have to wait until it sorts itself out (between 2-5mins or sometimes even 30mins) or do a hub reset. This has been happening for months.
What can I do?
  • jbrennand's avatar
    See this....
    Firstly... Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
    What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
  • Daniel_Et's avatar
    Daniel_Et
    Hi tomsvirg 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problem you're experiencing 😔
    In order to discuss this further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Thank you for your support jbrennand 👍
    Regards,
    Daniel
