DanMcD
Message 1 of 32
Removal of virgin media cable and box
Hello,
I've recently bought my house and there is a Virgin Media box and cable which runs through my front garden, over the top of my house, down the back of the property and into my living room.
I don't intend to become a Virgin Media customer and would like this cable removed if possible. It is causing an issues to my development of the property as we are planning on having a driveway installed to replace the original front garden.
The cable is in a green protective flexible pipe and hasn't been buried in the garden so presents a trip hazard in my front garden development. It's tricky to see because it's green in our overgrown front garden.
Would really appreciate any advice on how to remove this myself or whether virgin could please come and remove this from my new property.
Many thanks
Daniel McDermott
Travis_M
  • 3.28K
  • 113
  • 243
Message 2 of 32
Re: Removal of virgin media cable and box
Hi @DanMcD
Thanks for posting on our community forum!
I'm going to drop you a private message to investigate this further, please keep an eye on your inbox.
Travis_M
loucampbell2021
  • 7
Message 3 of 32
Hello,
I have the same issue as the person above, recently moved in, need to convert the driveway for wheelchair access and disability and there is a green cable running across the front garden to a box in the house that we are not using. We don’t intend to use it, how do we go about having this removed?
Thank you
Louisa
  • 5.83K
  • 481
  • 1.48K
Message 4 of 32
The green cable should have been buried in both cases, however if you get this all removed, VM may mark the property as "unserviceable" for any future users, or indeed yourself.
loucampbell2021
  • 7
Message 5 of 32
Thanks for the reply. It’s not buried that well, I nearly cut it with a trowel taking a plant out!
We have no intention of using virgin media in the future so it is fine for it to be removed permanently. We need to remove the box inside aswell to decorate.
Louisa
Corey_C
  • 5.23K
  • 258
  • 450
Moderator
Moderator
Message 6 of 32
Thanks for your post and welcome to the Community Forums, loucampbell2021,
To get the cable removed or reburied, I'll need to get your details so I can send it to the area manager. I've sent you a private message.
Cheers,
Corey C
lyzx
  • 5
Message 7 of 32
Hello Corey, team,
I am in the exact same position  after purchasing a property  - I need to have the box and wires removed before starting decorative works in the coming weeks.
Please could you get in touch.
thanks
Zach_R
  • 3.45K
  • 115
  • 241
Message 8 of 32
Hi @lyzx,
I'm really sorry to hear there's some unwanted cables on your property. I'll send you a private message in a moment to take a few details to get this sorted out for you. Please respond to this at your earliest convenience.
Zach - Forum Team
lyzx
  • 5
Message 9 of 32
Hi Zach,
We are approaching 4 weeks since I raised concerns on this. I am now faced with the possibility of putting my decorative works on hold. Could you advise of the complaints or escalation department.
many thanks
Kath_F
  • 32.23K
  • 1.23K
  • 2.59K
Message 10 of 32
Hi lyzx,
Thanks for your post and apologies to hear that no one has been in touch.
I can see that Zach has replied to your private message though advising on the next steps. If you have any further queries or questions, you can direct them to him through PM 🙂
Kath_F
