- jpeg1Alessandro Volta
You will always lose some range if the aerials inside the Hub are laid against a wall or a shelf which will absorb the signal. Try it and see.
More important is to avoid blocking any ventilation holes.
- ConfusedSpotJoining in
Thanks. It looks like it would cause a ventilation issue.
- Ashleigh_C
Hi there ConfusedSpot
Thank you so much for your post and welcome back to the community forums, it's great to have you with us.
We would not recommend tampering with the Hub as this can cause both ventilation and performance issues, can I ask if moving the Hub to another location would work for you? We can offer relocation appointments for a £25 charge where one of our engineer will come out to rearrange this for you.
Thanks, that might be helpful. What do I do?
Related Content
- 2 years ago
- 2 years ago
- 9 months ago
- 11 months ago
