on 06-12-2023 12:55
Does anyone know the cable type used from the wall socket to the Hub 5X for XGS Pon.
The cable the engineer installed is quite long and prefer to have a shorter cable.
Is Virgin able to supply a 1 metre cable that would be compatible as I bought one on Amazon and it does not fit the connection.
Thanks in advance
on 06-12-2023 13:10
I would expect VM should be able to supply you with a shorter cable but also see below
on 08-12-2023 13:47
Hey JDX98, thank you for reaching out and for your questions I hope the advice has helped below?
I can also see you've spoke to the team recently did they also manage to help?
Matt - Forum Team
New around here?
on 14-12-2023 00:31
I've still not been able to source one - primarily unable to find the correct cable and the one website I have found the correct one, charges a high delivery fee 🙁
Is VM able to supply a shorter fibre cable?
The recent contact is separate from this matter.
Thanks in advance
on 16-12-2023 11:17
Hi @JDX98
If you call the team on 150 / 0345 454 1111, as you're on the XGS service, you have a ring-fenced team that will help either order one or send an engineer out.
Best wishes.
