ck181's avatar
ck181
Connection issues
Only has virgin 3 weeks beginning to wish I’d not switched. I work from home and today lost connection said I wasn’t connected to the internet. Tried all the solutions offered nothing. Suddenly came back on its own, it has done that 4 times since very frustrating and not what I’m used to. Had to book a technician and that’s not till Monday so more work time lost. How can this be a connection problem at my end if it comes back by itself?
  • jpeg1's avatar
    jpeg1
    Have you lost connection by WiFi or ethernet cable or both? Where was the message that you were not connected?
    • ck181's avatar
      ck181
      Wi-Fi don’t have Ethernet cable
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there ck181
    I am so sorry that you have faced this issue with your service and thank you again for posting.
    I am glad to hear you have been able to arrange an engineer, are you able to let us know how things are looking after the visit?
    • ck181's avatar
      ck181
      Hi yes technician came out didn’t understand why it wasn’t working as there was no reason, changed the hub said it would be activated remotely. It has since been but no apps work, won’t turn off the channel it’s on and internet signal is showing poor. Been back in touch said they’d send a boost and to keep an eye on it for 48 hours. No use when I can watch only 1 channel and won’t be able to work from home. Really regret moving to virgin
      • -tony-'s avatar
        -tony-
        complete rubbish - they cannot send a boost whatever the hell that means and they will keep an eye on nothing - you have been royally fobbed off - but they care not as the call is marked solved
        wifi on vm hubs is generally poor even in the same room - you need to get hold of a lan cable and see if its ok with that - if it is then look at what you can do to improve the wifi - if its crap wired then its down to VM to solve
  • jpeg1's avatar
    jpeg1
    For boost, perhaps read booster/pod?
  • Hey ck181,
    We're really sorry to hear of the issues that you've had recently with your broadband services. How are things looking at the moment?
    Have you heard back from our team at all with any updates?
    Kind Regards,
    Steven_L
