- AdduxiVery Insightful Person
For £25 VM engineer will install any sockets, splitters, cables that you need. Be aware you can’t install this stuff yourself as it’s against the T&C’s of your Contract.
- SilverFox17Tuning in
The 'best' way to do this is to call VM and request a tech visit to do this, which will cost you £25 but, at least will be all 'above board' and if any issues in the future, you are covered!
Or you could take the risk of purchasing a splitter and cable from a 'well known site with a name similar to a tropical rain forest', and it'll probably all work OK. But if it doesn't then you have to swallow the loss and call VM and get a tech visit.
- ellisdcTuning in
Thank-you both. I think I'll contact VM as there are to many options out there and I'll probably end up wasting my money! What's the best way for VM would I just call them?
- Daniel_EtForum Team (Retired)
Hi ellisdc, thank you for your posts.
In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Thank you for your support SilverFox17 and Adduxi 👍
Regards,
Daniel
You can call and try to explain what you need, or you can wait here a few days for a VM Mod to pick this up and discuss with you directly.
Related Content
- 12 months ago
- 8 months ago
- 6 months ago
- 12 months ago
- 2 months ago
