- Client62Alessandro Volta
Get the Hub 3 working first ( with the VM Pod turned off ).
Once the Hub is connected and you can access the internet through it, then move on to the VM Pod.
- AdduxiVery Insightful Person
Also make sure the Pod is within range of the Hub to get a good Wifi signal. Pods will not work if the Hubs wifi is too weak to reach it properly.
- Peckham-pouncerTuning in
I have internet working through the pod as my WiFi signal is solid now on my tablet, without pod it's poor connection.
I have also factory reset hub3 & again rebooted pod, I've even placed pod in same room as hub 3.
My issue is the VM app can't see the pod it can't see it's health and It can't scan it.
It's probably virgins side that's not correct, I've read it could be they haven't set mac address for the pod properly.
- Daniel_EtForum Team (Retired)
Hi Peckham-pouncer, thank you for your posts.
We're sorry to hear about the problem you're experiencing š
Have you tried uninstalling and reinstalling the Connect app? Also, have you tried installing it on a different device to see if that makes any difference?
Thank you for your support Client62 and Adduxi š
Regards,
Daniel- Peckham-pouncerTuning in
I have the app on my tablet as well, I've uninstalled app on phone then reinstalled,it made no difference,it still shows connection unknown for the pod.
- MchugsJoining in
I have the same thing. Got 3 pods and a Hub 5 , The Connect app hasnāt been working for me for ages until a couple of weeks ago , now getting the below
ā
- Paul_DNForum Team (Retired)
Hi Mchugs,
Thank you for reaching out to us in our community and welcome, when a Pod is showing as unknown this can be due to it either being turned off, out of range or broken.
Are there any lights showing on the Pod, have you tried unplugging it and moving it closer to the Router?
Paul.
- AnotherHub3Tuning in
Did you get a reply? I rang VM and was given a "ticket" with a case number. Tech Support is next to nothing
Related Content
- 3 months ago
- 2 years ago
- 2 years ago
