on 18-05-2024 21:01
been a virgin client for over 10 years never had issue like now with hub5 net keep dropping every other min this is bad as hell i will hope for someone to contact me and sort this out of give me back my older router much better than hub5.
on 18-05-2024 22:05
Nothing wrong with a functioning HUB 5.
Sounds like you have a faulty one.
on 18-05-2024 23:56
The Hub 5 it is probably not the fault here - could you please provide the upstream, downstream and network logs from 192.168.0.1 (or 192.168.100.1 if in modern mode)
on 19-05-2024 17:17
The Hub4 and Hub5 use more frequencies on the cable than a Hub2 or Hub3. Most problems like this are down to a circuit fault. So please post some stats, details follow:
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
on 21-05-2024 18:00
Hi there @looper
I am so sorry to hear that you have faced these issues with your service and thank you so much again for posting.
Can I ask if you have the Hub in modem mode?
