lower speeds than paying for
Palm771
will the speeds fluctuate after first inisitial  installation of virgin media,  for the next few days?
Tested over ethernet connection to several different speed test sites
1 ACCEPTED SOLUTION
Accepted Solutions
Hi @Palm771
No, VM don't have a stabilisation period for the speed to settle down.
Even using the same speed test site when measuring the connection you will find the results vary. It will also vary using different browsers,
You should do a speed test using https://samknows.com/realspeed/ which measures the speed to your hub and to the device you are testing.
Dave
·.¸¸.·´´¯`··._.·* Wishing you a Merry Christmas and a Happy New Year *·._.··´´¯`·.¸¸.·´
8 REPLIES 8
jpeg1
No. What you have now is what you will get.
Post your speed test results, without including any personal data.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Use this link to check the service speed to the VM Hub & also to see the performance of your device.
Hi @Palm771
Dave
Palm771
okay thank you
I tried different web browsers and found out that my speed better when using a different web browser.
Thank you.
You can check the speeds you have compared to what should be achieving on the following page
https://www.virginmedia.com/broadband/our-speeds-explained
Looking at that your downlaod speed could be a tad higher, but there are no problems with your upload speed.
I tend to find that the results via a browser using speedtest.com can be lower than expected, this could be due to the browser itself, the number of tabs open, using a VPN or anti virus program, or other programs running in the background.
Do you have windows? If so download the ookla app (this is speedtest.com's app) and check the speeds using that.
Dave
Your advise was to try another web browser, I tried microsoft edge browser, and ran the speed test google provides, and it came back showing me 500mbps which I am paying for.
So you are correct trying a different web browser can make a difference
The whole point of the Realspeed test is it excludes your computer and browser from the speed test.
