Simbeag's avatar
Simbeag
Wifi
Not long had vm but can't get any WiFi in the kids bedrooms do vm supply WiFi extenders free or do they charge for one
    Regardless the best advice is to buy and control your own Wi-Fi Mesh / Wi-Fi Access Points / Wi-Fi Repeaters,
    having devices that are not owned by and limited by VM was critical for us.
  • jbrennand's avatar
    See this old post of mine
    ______________________
    To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
    You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - if you are - it is clearly stated on the webpage.
    You can also text VM on 0753 305 1809 include account name/number and what the issue is, there is also a “Chat” option on their website - but note that replies usually take longer. Or you can speak to the team on WhatsApp by logging into your online account via a mobile handset and there will be a link to speak to VM by Whats App (the number is 0780 3089 684 ) - you can use the same number for their other social media platforms too (TwitX/Fbook. etc) - so try them all
    If not free to you… you will be charged £8/month for up to 3 pods. It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
    If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point(s), (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
    £40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
  • Hi Simbeag 👋.
    Thanks for reaching out to us, and welcome to the Community Forums. Sorry to hear that your Wi-Fi is not fully extending to the kids bedroom. We do have our Wi-Fi Max pods, if you have a 1gb package or are a Volt customer these are part of your package and not chargeable, otherwise it is £8 a month and that covers you for 3 pods (depending on diagnostic results) as well as our Wi-Fi Max Guarantee, which can be found under the Wi-Fi Max pods Link.
    If you have been able to get this resolved please let us know. Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
    Thanks.
    Sabrina
