lukes___
1 year agoJoining in
Wifi Pods (white) - great tech, shame they're so tetchy
So my first pod (#1), just failed to work at all and was sent back. The replacement one (#2) worked fine first time and I added a second pod (#3) for best coverage.
Worked ca. 1 month - then just stopped.
#1 - when plugged in -> light blue light then blue light / green light / no light then cycles back to blue light. Doesn't get assigned an IP address by VM Hub so basically invisible to the network
#2 = when plugged in -> white led then pulsing white led. No assigned IP address.
(does anyone know what the leds mean - i read somewhere that white pulsing is no network signal?)
Both tested less than 10m from VM hub wifi
So basically, two more dead pods?
