Wifi Pods - how to order
John511
Hi, I have the volt ultimate bundle, Have a loft extension and am hoping I can get a couple f wifi pods to boost the signal.
Thanks.l in advance
1 ACCEPTED SOLUTION
Accepted Solutions
The official route is to use the VM Connect app to scan the whole property and then it should allow you to order one Pod initially.  If this does not work, then wait here a day or two for a VM Mod to pick this up and discuss with you.
However, you may be better to run a Cat 6 cable from the Hub, even externally btw, up to your roof space for a better solution.
4 REPLIES 4
Ilyas_Y
Hey @John511 Thanks for reaching out to us on the Virgin Media forums. 👋🏼
I'm sorry to hear about the issues with the pod ordering you are experiencing.
I will assist you on this and get this sent out.
I will send a private message.
Kind regards,
Ilyas.
Ilyas_Y
Thanks for the info.
Ilyas_Y
Thanks for speaking with us today @John511 on the Virgin Media forums. 👋🏼
I'm glad we have been able to assist and get a Wi-Fi pod ordered out.
As advised, the information in the chat has all the details for the delivery date etc.
Let us know how it goes once it arrives and reach out to us for any other queries and we'll assist where we can.
Kind regards,
Ilyas.
Ilyas_Y
