- dhairbusDialled in
A full 60 second reset may clear the issue (but for me the fault re-appeared within a day).
It's becoming a common issue lot's of threads but in reality the Hub 4 is failing/faulty or the firmware has a serious bug. I have spent many times calling this in and the customer support is a disgrace. Customer Support told me a replacement HUB would be sent still waiting and now told nothing wrong and no replacement HUB ordered If it's not in their "script" they cannot help. Raise a complaint. VM know there is an issue but don't acknowledge the fact.
Virgin Media was the most complained about..........OFCOM
OFCOM need to start getting serious suppliers who do not perform to a minimum standard and hit them with really heavy penalties.VM pay lip service to customer complaints.
- Matthew_ML
Hey Chiggins23, thank you for reaching out and I am so sorry to hear this.
If this is a new hub a reset may help, did the advice help of a full reset?
Please do let us know.
- Chiggins23Joining in
Hi, full reset has not solved the problem. What else can you suggest please?
- Daniel_EtForum Team (Retired)
Hi Chiggins23, thank you for your response.
Have you tried uninstalling and reinstalling the app?
Also, can you please confirm the type of device you currently have it installed on?
Regards,
Daniel
- Client62Alessandro Volta
If after a 60 second reset, the Hub 4 admin menu is not working, the Hub 4 has failed.
Request a replacement.
Related Content
- 2 years ago
- 2 years ago
- 2 years ago
- 4 months ago
