Geoff77
2 years agoJust joined
WiFi drops out every 2 weeks - modem mode
Every two weeks - usually a Tuesday morning at about 3am - I lose connection to my Virgin WiFi. As I run my home WiFi on Modem Mode, it means I need to spend approx 30 mins resetting the Hub5 and then re-establishing connection across my other WiFi points using my laptop, ethernet cable etc. Why is this? And can it be fixed? These regular and persistent outages are especially annoying as I run my security cameras on the WiFi signal and I can't reset the connection remotely when on holiday etc. Thanks. (Virgin make it impossible to ask them this question so over to you!)
