MatthewPerren's avatar
MatthewPerren
WiFi continually dropping out - Hub 3
We have a hub 3 with TP Link extenders.
WiFi continually drops out even if we turn all the extenders off. We’ll get a signal but no internet connection.
The Ethernet connection I get through a TP link extender is pretty solid in comparison.
It’s getting to the stage that we are considering leaving Virgin.
(also TV signal is glitching but I’ll post this separately)
    We’ll get a signal but no internet connection. ( from the VM Hub's Wi-Fi )
    The is all too common when a member of the home has used the Connect App to Pause Wi-Fi
    i.e. block devices from connecting to the internet via the VM Hub's Wi-Fi
      • Carley_S's avatar
        Carley_S
        Hi MatthewPerren
        Sorry to hear of the issues you're having with your WiFi.
        Checking the systems on our side, we can't see any issues in the area or with our router's specifications that might explain a fault on our side.
        Do you find that this issue occurs when you're further away from the router or in certain rooms of the home?
  • legacy1's avatar
    Stop using  extenders with the hub get a better wifi router with 1Gb ports and use hub in modem mode
