on 29-05-2024 15:02
While with my Hub 2 Modem Only worked fine with my netgear router. For some reason the Hub 3 does not work.
the only way i coudl get it to work was by setting it back to Router. Then it worked. Though now i have 2 wireless networks running....
which leads me to Port forwarding and Minecraft
on 29-05-2024 15:04
use modem mode with a PC get that working then copy PC MAC to your netgear router WAN interface
on 06-06-2024 13:57
if i can understand this - i might give it a go. but at the moment it is workin (even if i means both are routers and a minecraft server is extra painful )
