feygor's avatar
feygor
Hub 5 Modem Mode not working
Hi, not sure if anyone has a similar experience, but I've always used my hub 5 in modem mode, had it for about a year without any issue, randomly it has swapped back to router mode and trying to switch it back into modem mode it just hangs at the screen telling you it's restarting, except it doesn't restart.
My whole network is a mess unless I can get this working again - I've tried a restart, tried a factory reset, tried a hard reset, all successfully reset the device but modem mode still doesn't work - I'm assuming VM has pushed a buggy firmware update, anyone who a way of rolling back?
  • Try the pinhole again but keep it pressed in for >60 seconds and see if that sorts it
  • jbrennand's avatar
  • feygor, I experienced this issue around the same time after years of working just fine. Had to switch back to router mode and double NAT to get connected. Are you still having the same issue? I'm convinced it must have been a buggy firmware update to now.
    • feygor's avatar
      feygor
      Got it sorted in the end, after a few more reboots I decided to just leave it, actually took ~17 mins to boot to modem mode, much longer than the ~2 mins it should take - can only imagine this is a firmware issue, waiting for services to time out rather than killing them etc, at least it's sorted.
  • Thanks for reaching out to us feygor and a warm welcome to our Community Forums
    Sorry to hear of the issue experience via Modem Mode on your Hub 5.
    Do feel free to report back to us to confirm if the aforementioned advice has been successful and that this is now resolved.
    David_Bn
    • legacy1's avatar
      If your making us wait for modem mode to work on reboot then its hardly resolved what you now doing validating MAC's on the network by hand for those using modem mode or even slower firmware boot?
  • dts439's avatar
    dts439
    I had same issue with Hub 5 not going into modem mode.  At some point after various diagnostic tests it had left the hub in router mode without me realising. Attempting to set modem mode just left it in white mode and on 192.168.0.1 (and sometimes claiming to be in modem mode).
    As above, holding reset in for >60 seconds allowed me to then set modem mode from 192.168.0.1.  It restarted, flashed green briefly before flashing white as per normal startup.  After around 2 minutes it briefly flashed blue before going solid green.  Hub then responded to 192.168.100.1 as expected.  Further reboots (to allow it to bond with the mac on my router) followed the same pattern and all ok again,
