Using a Managed Switch.
fatchapchipchop
I am introducing a managed switch which has PoE and non-PoE RJ45 ports so that I can distribute fixed and wireless access points in my house, and further into my garage and summer house.
My questions are:
What is the DHCP range for my VM router. I need to know the range so that I can give my switch a fixed IP address outside the DHCP range.
I need my router credentials, which I have never received, so that I can login to the router and disable wireless as I will have separate access points on my structured cable setup.
1 ACCEPTED SOLUTION
Accepted Solutions
You can log into the settings on a browser using -  http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return.  Then use the settings password on the base sticker - not the wifi one - and log in
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
3 REPLIES 3
Thanks John, exactly what I needed !!
I always keep my network equipment in the range 220 upwards. 22x for Pinhole DNS servers, 23x for cameras, 24x for switches  & 25x for APs.
