colinwebb's avatar
colinwebb
10 months ago
Upgrade to hub5
I’ve noticed twice now that the hub 4 I have has got quite hot and started blinking blue. Resetting solves the issue but I’m wondering if an upgrade to hub5 would solve this. I’m on the Gig1 package.
  • jbrennand's avatar
    Call it in as a fault and a Tech visit will be arranged who, if faulty,  may swap the Hub for you - it could be a Hub5 or a Hub5 - dependent on what they have in their van.
  • nodrogd's avatar
    nodrogd
    By all means report it as a fault. But the technician will replace it with whatever happens to be in their van at the time. At the end of the day the kit is rented & VM only has to provide you with a router capable of the broadband speed you pay for.
  • jpeg1's avatar
    jpeg1
    And if the technician finds there is no fault you may be charged £25.
  • I know this isn't a place, but my first post has been marked as spam, can a moderator or anyone look into that please? I feel like I'm being ignored by Virgin on all mediums.
  • Hi colinwebb
    Welcome back to the community forums
    Sorry to hear of your concerns with your Hub 4.
    When the Hub 4 flashes blue this means that it's trying to gain a WPS connection as it's been requested to do so from the button on the back of the hub.
    Is the router in a open, well ventilated area  and out of direct sunlight? Are you experiencing any service issues at all when the light flashes or just in general?
