on 24-02-2024 16:45
Hi i need to be sent a replacement superhub 3 as it has a constant red light at the bottom instead of white which means its overheating acording the the VM website and my internet keeps dropping out and i have to turn the hub off constantly to get it to work.the hub is in a an open well ventilated area also so thats not the cause
on 24-02-2024 20:43
Run the Hub 3's Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ?
on 25-02-2024 01:13
as you can see it says the temperature is normal so obviously something is wrong with the hub
on 25-02-2024 01:38
So its not overheating. But the warning system to detect and warn you of that "state" is not working properly.
A bit like removing the battery from your smoke alarm detector !
on 25-02-2024 10:14
On the screen shot we don't see the temperature report.
However if it is normal that is good news, the LED's colour is fading.
When a Hub 3 is in modem mode the LED is magenta and that looks quite red to many folks.
