Super hub 3 solid red light
rebster
I have a solid red light on my super hub 3. It was only changed a couple of weeks ago.
the router is out in the open so should not be over heating. I get occasional drop out
4 REPLIES 4
John_GS
Good evening @rebster
Thanks for posting and welcome back to the community. It may just be a failing LED light but to be sure, could you please can you try the below;
•             Turn the power switch off on the back of the Hub.
•             Ensure the Hub is upright, in a well-ventilated location and out of direct sunlight, if possible.
•             Switch the hub back on at the power. The Hub should now operate normally
Let us know if this fixes things 🙂
John_GS
Hello John
i can confirm, I have switched off the router and back on. The red light is still present and the hub feels quite hot to the touch. Is it possible to request a new router for peace of mind. I’m guessing as this is an old model now most replacements are refurbished items. If possible I would like a new replacement please
Thanks for the reply @rebster on the Virgin Media forums. 👋🏼
We appreciate you letting us know that the above has not worked.
If the hub is overheating more than usual - please do turn the hub off and take it out and leave it to cool down somewhere safe to prevent any fire damage.
I will continue in getting this replaced as it does need to be addressed.
I will send a private message.
Kind regards,
Ilyas.
Ilyas_Y
thank you very much for your help. I look forward to my new router
