neizt's avatar
neizt
Stats check - cable damaged
Hello community 👋.
Been a Virgin customer for over 10 years now and have thankfully had very few issues. Recently we had some work done in the garden which resulted in my Virgin cable that runs through the said garden getting damaged.
Copper was showing but repaired using electrical tape as a temporary measure, thing is my connection still seems as good as it was before. Is it still worth getting an engineer visit to sort it properly?
Router stats attached below:
Router status
3.0 Downstream channels
1 331000000 6.2 43 QAM 256 25
2 139000000 8.2 43 QAM 256 1
3 147000000 8.2 43 QAM 256 2
4 155000000 8.1 43 QAM 256 3
5 163000000 7.9 43 QAM 256 4
6 171000000 7.7 43 QAM 256 5
7 179000000 7.7 43 QAM 256 6
8 187000000 7.8 43 QAM 256 7
9 195000000 8 43 QAM 256 8
10 203000000 7.9 43 QAM 256 9
11 211000000 8 43 QAM 256 10
12 219000000 8.1 43 QAM 256 11
13 227000000 8 43 QAM 256 12
14 235000000 7.8 43 QAM 256 13
15 243000000 7.7 43 QAM 256 14
16 251000000 7.6 43 QAM 256 15
17 259000000 7.3 43 QAM 256 16
18 267000000 7.2 43 QAM 256 17
19 275000000 7.2 43 QAM 256 18
20 283000000 7.1 43 QAM 256 19
21 291000000 7 43 QAM 256 20
22 299000000 6.9 43 QAM 256 21
23 307000000 6.8 43 QAM 256 22
24 315000000 6.6 43 QAM 256 23
25 323000000 6.4 42 QAM 256 24
26 339000000 6.1 42 QAM 256 26
27 347000000 6.3 43 QAM 256 27
28 355000000 6.4 43 QAM 256 28
29 363000000 6.2 43 QAM 256 29
30 371000000 5.9 43 QAM 256 30
31 379000000 6 43 QAM 256 31
32 387000000 5.9 43 QAM 256 32
1 Locked 43 0 0
2 Locked 43 0 0
3 Locked 43 0 0
4 Locked 43 0 0
5 Locked 43 0 0
6 Locked 43 0 0
7 Locked 43 0 0
8 Locked 43 0 0
9 Locked 43 0 0
10 Locked 43 0 0
11 Locked 43 0 0
12 Locked 43 0 0
13 Locked 43 0 0
14 Locked 43 0 0
15 Locked 43 0 0
16 Locked 43 0 0
17 Locked 43 0 0
18 Locked 43 0 0
19 Locked 43 0 0
20 Locked 43 0 0
21 Locked 43 0 0
22 Locked 43 0 0
23 Locked 43 0 0
24 Locked 43 0 0
25 Locked 42 0 0
26 Locked 42 0 0
27 Locked 43 0 0
28 Locked 43 0 0
29 Locked 43 0 0
30 Locked 43 0 0
31 Locked 43 0 0
32 Locked 43 0 0
3.1 Downstream channels
159 94 4K 1840 QAM 4096 1108
159 Locked 43 3.2 69503371 0
3.0 Upstream channels
0 49600000 43 5120 QAM 64 1
1 43100000 43 5120 QAM 64 2
2 36600000 42.5 5120 QAM 64 3
3 30100000 42.3 5120 QAM 64 4
4 23600000 41.8 5120 QAM 64 5
0 ATDMA 0 0 0 0
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
3.1 Upstream channels
6 10 37.5 2K QAM 256
6 OFDMA 200 74000000 0 0
  • asim18's avatar
    asim18
    Rising star
    If your cable is damaged to the core it may work fine for now, but it won't last very long. Eventually, moisture will get in and slowly ruin the surface of the copper conductor which will begin causing problems sooner or later.
  • The stats look okay to me but a agree that it is probably prudent to call the damaged cable in as a fault on 0345 454 1111 / 150. It would also help to see the current state of the cable via some pictures.
    Hopefully it was only the outer sheath you saw as copper.  If it was the inner core, your stats would be terrible, but as it is, they are not bad at all.   However, agree that over time water ingress may cause problems, so best to get the cable repaired by VM.
