sanjb20's avatar
sanjb20
Spare Coaxial Cable
Hi I've got an additional coax cable installed in my study/office. Does this cable give off an internet signal. Can I use it to for internet usage away from the main hub as the distance is weak based on its location.
1 Reply
    You can possibly move the Hub to that location and see if it works.  It may be disconnected in the Omnibox outside however.  You can't use it for "additional" internet as it needs to be connected to the Hub.
    If you need to improve the Wifi in your location, consider buying a decent Wifi extender/Access Point etc.
