Solid red light on Hub 3
BigAl_R
For a couple of weeks I have noticed that the constant white light on my Hub 3 has changed to a constant red light (see the attached photo). I have reset, rebooted, unplugged & plugged back in again, but to no avail - the light remains constant red. I still get a wifi signal in the house, although it does seem to vary in strength these days, but I am reading on the community that this could be an problem whereby an engineer is required and a replacement hub. Please can you provide some advice and assistance with this. Thank you.IMG_8272.jpg
1 REPLY 1
Arissa_H
Hi BigAl_R 👋🏼
Thank you for posting, welcoming you back onto the community forum 😊.
Sorry to see your hub light is on red ☹.
I will have to further investigate into this 🧐, by sending you a private message.
Please watch out for the envelope ✉.
Thank you.
Ari - Forum Team
New around here? To find out more about the Community check out our Getting Started guide
