3 weeks ago
Hello,
I had my Virgin Hub3 for at least three or more years and few weeks ago it started showing a solid RED light. My first impression was that it will go away by itself in a day or two and when it didn't I searched on the Virgin support. I followed some instructions such as switching the hub for 15mins and reseting it using a pin, etc. The hub isn't that hot and sits where it was over the years so something isn't right. I would like someone 'Tech' to come and replace it please.
Answered! Go to Answer
3 weeks ago
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
3 weeks ago
Hello,
I'm experiencing the same issue with my Hub3.0 for the past few weeks and have gone through the troubleshooting steps listed on the site. If someone could please assist us with this it would be appreciated.
3 weeks ago
3 weeks ago
Hi there @pberhane
I am so sorry that you have faced this issue with your service and thank you so much again for posting. Can I ask if you have been able to try the pin hole reset at all as advised by Adduxi?
3 weeks ago
Hello Ash,
Yes I did follow all the required instructions from Virgin such as switching it off for over 15mins, check if its abnormally hot, reset the small button using a pin and none of these made a difference. The overall functionality of the hub seems to be fine, I checked download/upload speed using the WiFi and all ok.
The hub has been at the same place and position over the years and nothing has changed in my living room.
It does look like it needs replacing please.
Thank you.
Mr. P Berhane
2 weeks ago
Hey @pberhane,
Thanks for getting back to us, with this we would now need to look into sending out a technician for you to go about replacing this, for me to go about doing this, I will need to go about sending you a private message.
Joe
