Smart bulb won’t connect to hub 5
Joelhanjon-23
Looking for help!! Recently bought 3 new Tcp smart bulbs. And having a right carry on getting them to connect. After hours of trying to connect and searching the internet for help! Tried the suggestion of turning off 5ghz to only 2.4ghz. Which still didn’t help 😐
I managed to get them connected using my phones hotspot 👍🏻
But then when I reactivated the 5ghz they became off line and couldn’t connect to server.
My parents had the same problem with there smart plugs when they upgraded there router but I didn’t have nearly enough trouble with there’s as I am with mine!
What am I missing! Can anyone help before I throw the router box out the window 🙃
Thanks 🙂
1 ACCEPTED SOLUTION
Accepted Solutions
Throw in your own router with 1Gb ports and use hub in modem mode
4 REPLIES 4
Ilyas_Y
Hey there @Joelhanjon-23 Thanks for reaching out to us and a warm welcome to the Virgin Media Community forums. 👋🏼
I'm sorry to hear about the issues with the smart bulb and the hub 5 you are experiencing.
May I ask if you've managed to get this sorted with the advice on the thread or still need more assistance?
Let us know.
Kind regards,
Ilyas.
Ilyas_Y
Thanks for the advice! 🙂
Seems the OP has already sorted this one out himself.
(1) Smart bulb too far away from router ?? - Virgin Media Community - 5476785
