Joelhanjon-23's avatar
Joelhanjon-23
Smart bulb too far away from router ??
Hi everyone
after days of trying to connect my Tcp smart plugs to the hub 5 I managed! (FYI I disabled the 5ghz AND the disabled the smart Wi-Fi function that seems to do the trick)
but now I have another problem!
one of the bulbs i want to use is outside above the back door, (one of the other bulbs I got working was for the porch so I assumed I could put one at the back door too) but it says it can’t find the Wi-Fi. I’m assuming it’s because it’s past thick walls and further away from the router.
I went online and was suggested a power line adapter but I think I’ve bought the wrong one 😵💫
any advice on what I should do ? Or on what I could buy ?
thanks 🙂
