ptognarelli's avatar
ptognarelli
Remove Broadband and Phone Cable Buried in the Ground
My house includes a disused box on the wall for two old broadband and phone connections.  Digging my garden revealed these extend to a green tube only buried a shallow depth into the ground.  Can I just remove all these myself?
  • VM will generally not remove them for you unless there is some sort of H&S risk involved.
    It is not uncommon to find VM cables on one property may serve other properties elsewhere. You mention two connections. Is that two broadband cables and two phone cables or two cables for broadband and phone? How have you confirmed they are disused? Can you see the cables go no further than the outside box?
  • goslow's avatar
    goslow
    • ptognarelli's avatar
      ptognarelli
      Two cables run through the ground into the box and then two leave the box to a socket inside the house -- I assume one for the broadband and one for the phone line.  These both worked on first moving into the house but I can confirm them last used 14 years ago!
      • Gareth_L's avatar
        Gareth_L
        Hello ptognarelli.
        Looks like your question has been answered already, Thanks for asking though.
        We would not remove then unless they are a trip hazard and would advise leaving as they are incase a property owner or tenant wishes to get our services in the future.
        Gareth_L
