House58's avatar
House58
Red flashing light
Hi, around 9pm on Thursday evening our Wi-Fi stopped working. Since then we have had intermittent Wi-Fi. It’s mainly not working but does occasionally come back for a few minutes. I’ve reported it to VM and have an engineer booked for Monday 4pm-7pm, this was the earliest slot available.
I’ve turned it off and on again several times and checked cables etc but not sure what the cause could be.
How do I do a factory reset? I’ve called VM several times, but it’s still not working and the only things they have suggested is that I turn it off and on again. Thanks
  • Hi
    I’ve google how to find out what hub I have (hub 5) and where the reset button is. I phoned VM lots of times over this issue. I have two children needing the internet. One needs to submit a university assignment by 9am on Monday and the other has mock exams next week. School have lots of online study links. I’m glad it’s not his real GCSEs. It has really made me realise how much we rely on Wi-Fi, not just for fun things. I also work from home and will have to commute to work on Monday as it doesn’t look like it is going resolve soon.
    The reset doesn’t seem to have worked.
    I have checked the status of the router (following instructions from an old post). I have no ideas what they mean.
    13-10-2024 03:01:44noticeGUI Login Status - Login Success from LAN interface
    13-10-2024 03:00:09noticeGUI Login Status - Login Fail from LAN interface
    13-10-2024 02:59:04noticeGUI Login Status - Login Fail from LAN interface
    13-10-2024 02:58:22noticeGUI Login Status - Login Fail from LAN interface
    13-10-2024 02:10:07warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:10:05errorDBC-ACK not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:49noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:49warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:40noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:24warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:24noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:21warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:21noticeREGISTRATION COMPLETE - Waiting for Operational status
    13-10-2024 02:09:15noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:14noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:09warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:09:07noticeHonoring MDD; IP provisioning mode = IPv4
    13-10-2024 02:08:58criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:56warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:41noticeREGISTRATION COMPLETE - Waiting for Operational status
    13-10-2024 02:08:39warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:33noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:32noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:26warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:23criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:19noticeHonoring MDD; IP provisioning mode = IPv4
    13-10-2024 02:08:11warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:08:10errorDBC-ACK not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:07:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:07:54warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:07:34noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:07:30warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:07:30noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:07:27warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    13-10-2024 02:07:27noticeREGISTRATION COMPLETE - Waiting for Operational status
    13-10-2024 02:07:21noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    If there is anyone that c/m can help, I would be so grateful.
    Thank you 😊
      • House58's avatar
        House58
        3.0 Upstream channels
        Not Available
        Not Available
        3.1 Upstream channels
        61053.02KQAM 256
        6OFDMA2007400000000
  • jpeg1's avatar
    jpeg1
    Your downstream levels are far too low. The technician will need to fix this.
    • House58's avatar
      House58
      Thank you for your reply. Hopefully the engineer can sort it. They are booked for tomorrow.
      I’ve been with VM for years, and have never been offline for this amount of time.
