- Mo18Joining in
Phoned customer service and was told as long as I have Internet connection they won't give me a new hub
- Daniel_EtForum Team (Retired)
Hi Mo18, thank you for your response.
The red light indicates that either the router is overheating, or there's an issue with the connection to the LED.
Can you please follow the below steps in the following order in the first instance:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Then use the power switch to turn the unit back on
If after following the above steps the router doesn't boot back up after a few minutes, or the red light returns when it does, the router will need replacing.
Regards,
Daniel- Lesp1964Tuning in
Hi Daniel _ Et ,
I started having the same problem yesterday , and have done what you said to do , but the red light is still on .
- Mo18Joining in
Hi Daniel_Et
I've done as you suggested. I've called customer service and they said as Internet connection is working they will not replace the hub. Do you have any other suggestions?
Morag
- Cordelia29Just joined
I have exactly the same issue except the Wi-Fi works but Ethernet doesn't
- Kath_P
Hi Cordelia29,
We're very sorry to hear you're having some issues with your Hub 3 displaying a red light. Just to double check, is the Hub currently in modem mode? If so then the light will be a magenta colour but can look quite red at times. This is perfectly normal and nothing to worry about.
If it's not then please follow the below steps:
- ➡ Turn the power switch off on the back of the Hub.
- ➡ Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight.
- ➡ Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the red light still shows after doing the above, pop back here and let us know. We can then arrange an engineer to visit to swap out the Hub.
- geoffsterJoining in
I have exactly the same issue a continuous red light on a hub 3. I am having no joy navigating through Virgin's mire to try to get a resolution.
- Steven_L
Hello geoffster,
Welcome to the Community and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re having with your router at the moment. I'd be happy to take a further look into this for you however I would need to confirm a few details via private message, please look out for my message and we can get started.
Kind Regards,
Steven_L
- siddmishraJoining in
Hi there,
I'm experiencing the same issue with my Virgin Hub 3, which I’ve been using for the past seven years.
I’ve followed the instructions to reset and restart the hub. It’s not exposed to direct sunlight, and the issue still hasn’t been resolved.
if you can please help me to guide on the next steps.
- John_GS
Hello siddmishra
Thanks for posting and welcome to the community. Thanks for notifying us about the red light and what you've done already. I'll send you a PM, get some details and book an engineer visit.
Best wishes.
- Trevor11Tuning in
Hi - I am having exactly the same problem. I have tried all of the recommended reset options and the red light is still on
- Trevor11Tuning in
Mine is doing exactly the same - it is a Hub 3 and I have tried all of the recommended reset actions
- Molly_T
Hi Trevor11 👋 Thanks for joining this thread!
Sorry to hear about the red light on your router. From the looks of things you've also started your own thread 👉 here, where my colleague has responded offering support via PM. They will be able to help! Thanks for your patience in the meantime. 🌞
Related Content
- 3 months ago
- 2 years ago
- 2 months ago
- 2 years ago
