Order WiFi pods please
cajhughes
I recently signed up for Gig1 Full Fibre, and would like to order some WiFi pods as the signal does not make it up to the top floor of my house. Can anyone assist please?
Many thanks!
1 REPLY 1
See this
________
VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - if you are - it is clearly stated on the webpage.
