Yellowbelly's avatar
Yellowbelly
Network Issue
Apart from receiving a text message (it is the only notification I have received) to tell me that there are network problems in my area.
When and how am I going to be informed about the fibre network problems resolution in my area?
  • jbrennand's avatar
    See this
    ________
    Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    You could also use the /check-services/ function and if there's a fault listed you can click a radio box to be updated either by email or sms.
  • Roger_Gooner's avatar
    Roger_Gooner
    Occasionally I get both a text and an email telling me of an area problem, and I also got same when problem was fixed.
